beocom 2
Jenette
Posts 8
Jenette Posted: Thu, Mar 28 2013 11:47 AM
Hi can any one tell me if a beocom 2 which is registered to a mk1 pstn uk model will this work in greece?
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Thu, Mar 28 2013 4:47 PM
Has it an rj45 plug and is working in UK ?
It should do but might require an adapter as bt use the outside pair of wires in the plug and most other telecoms use the inside pair.
root
Posts 226
root replied on Thu, Mar 28 2013 6:13 PM
It will work fine given you buy the proper adaptor from RJ11 to the plug that is needed in your country:
http://www.multitel.co.uk/greece.html (no need to buy in the UK, should be available everywhere cheaply in Greece, you just need the adaptor from RJ11 to the greek one, not from BT to greek...)
Page 1 of 1 (3 items) | RSS
