i recently purchased a beocenter 8500 which needed the belts replaced which i have done and also stuck the glass panels back. It now works perfectly apart from the CD motor noise that comes through the left hand speaker. The tape section works perfectly without any noise.
Any help would be very much appreciated.
Thank you.
CD motor noise?Do you mean just when the cd is turning?Does it vary as the laser follows the disc,eg as the disc slows down towards the end of the disc?
Nick
Which speakers are you using ?
