Cannot seem to find a forum for Beocom 5 telephone.
Am getting a message 'Line busy, Break In ?'
Cannot make any calls or receive calls.
Checked all connections, and the other phone is sitting correct in cradle.
Can anyone kindly help me, as stuck over |Easter with no land line phone. (B&O closed for Easter)
Cheers
Try to switch the Beocom off by pressing the key in the middle till your Beocom switches off. Wait 5 minutes and switch it on by pressing the same button.
You can even try to disconnect your Beoline from the mains for a while.
Also, if the above steps will not work, try to register your Beocom to the Beoline. Success!
Beocom is losing connection with the base.
that's a problem with cheap telephones!!!!
