Beocenter 6 26, Type 9282, error codes
misterbe
Posts 5
misterbe Posted: Sun, Mar 31 2013 2:45 PM
Does anyone know what the errror codes below mean shown in the Monitor Service Menu under Monitor Information?
TV 0330 22-2D
TV 0331 40-1
ML TD
Roger
Norway
Posts 417
Roger replied on Sun, Mar 31 2013 3:08 PM
ML TD = ML data pulled down (short circuit).
Will have to check the TV errors, but the first four digits are month and date (TV 0330 = TV error on March 30th).
Roger
Roger
Norway
Posts 417
Roger replied on Sun, Mar 31 2013 3:15 PM
On March 30th you had an error related to the M2 processor, and to the CTI on March 31st. These are all bus addresses: An IIC bus error means that the communication on the bus fails when the microcomputer tries to communicate with the address in question.
Roger
misterbe
Posts 5
Hi Roder
Thanks you for your prompt reply ... do you think there is something seriously wrong with the TV or just a one off malfunction?
Berthold
Page 1 of 1 (4 items) | RSS
