Try switching the input cables and maybe even the locations where they're plugged into power (unless they are plugged into the same outlet) and see if the right speaker still makes the same noise. If the noise persists even when switching the input cables, you at least know the source of the noise is not likely to be coming from upstream in your equipment.
Hum like that could also be caused by some type of device nearby, such as a mobile phone or other wireless device.
