MX Power Cable Strap - How to open/loosen up?!
Simon
Sweden
Posts 9
Simon Posted: Thu, Apr 4 2013 9:45 PM
Hey guys!
I'm new to the forum and I'm very pleased to be apart of the community so thought Id give it a try and get help with my everyday B&O problems ;)
I'm currently owning 4 beautiful MX series Bang & Olfusen TV´s, but they all got the same bloody problem! The strap that is suppose to hold the power cable while transporting is tied up and I havent been able to loosen it up, Its just impossible! Does anyone have a secret method or fix to get these badboys open?
Thx in advance! //Simon
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Apr 4 2013 9:53 PM
Hello and welcome to the forum,
I had the same problem earlier in the week!  It is fairly counter-intuitive: With one hand you need to push the little tab upwards (or away from the loose end) and at the same time use the other hand to push the loose end through (under?) the tab to loosen the strap.
I hope this helps!
Simon
Sweden
Posts 9
Simon replied on Thu, Apr 4 2013 10:20 PM
IT WORKED! Thx alot, you got my B&O blessing ;)
Page 1 of 1 (3 items) | RSS
