Beogram 4004 won't track
This post has 15 Replies | 1 Follower
customxke
Posts 7
customxke Posted: Mon, Apr 8 2013 1:57 AM
 I have a lovely 4004 paired with a Beomaster 2400. Everything powers up, and sound great. The 4004 however doesn't track. The belt on the carriage motor is fine. The transport lock is in the "play" position. Lubricant isn't hardened. I'm handy, but not a tech. Is there anything else I can look for before I pony up the money to replace or repair this?
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Apr 8 2013 11:07 AM
How do you mean? Does the arm move and drop? Is it that it does not move once on the record?
Peter
customxke
Posts 7
The arm drops, but does not move.  Not on the record, nor off the record.
Søren Mexico
Mexico City
Posts 6,411
Does the arm drop on the record, and then does not move, or does it drop off the record. Check that your pickup has a needle and that the needle is riding in the record track, check the weight adjustment is set correctly.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Apr 8 2013 5:05 PM
Sounds like the light sensor is not working - either the light sensitive resistor or the bulb. Would be beyond me personally but it is fixable!
Peter
customxke
Posts 7
Has a cartridge.  It plays, but the carriage won't move, so it only plays as much as the lateral play in the arm allows.  The light works.  I suppose it could be the sensor, or the carriage motor.  Ugh.
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Apr 9 2013 9:59 PM
But the carriage motor works to get the arm to the right place - probably the sensor.
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Apr 9 2013 10:52 PM
The sensor and the lamp.
In a closed compartment at the foot of the carriage.
customxke
Posts 7
customxke replied on Sat, Apr 13 2013 4:10 PM
The carriage doesn't move.
Dillen
Posts 13,191
Dillen replied on Sat, Apr 13 2013 4:30 PM
Check the opto at the carriage foot (as already suggested).
An interrupter operates with the tonearm and goes between the lamp and the sensor.
If the lamp has burned the carriage will not follow the tonearms movements.
customxke
Posts 7
customxke replied on Sat, Apr 13 2013 5:21 PM
The bulb is ok.  I found and fixed a bad connector, and now the carriage motor works. The LED in the pic below isn't lighting.
Dillen
Posts 13,191
Dillen replied on Sat, Apr 13 2013 6:11 PM
The LED in the photo is not sitting at the foot of the carriage but rather on a PCB at the subchassis.
The LED in the photo is not emitting visible light. It's Infrared. You need a digital camera (cell phone) to see the light.
The LED in the photo is not related to the tracking. It signals the setdown and end-of-record points to the electronics based
on the patterns of the ruler that travels between the LED and the sensor on the other side.
The tracking is controlled by a small filament lamp and a sensor, sitting in a housing closed off from ambient light at
the base of the carriage.
customxke
Posts 7
customxke replied on Sat, Apr 13 2013 6:28 PM
I already checked the filament lamp, and its working. Didn't know the LED was IR. thanks for that. I'm kind of back at square one now with new problems. Carriage motor now returns the carriage, but won't shut off once the carriage is in the full reset position. The stop button raises the arm, but the main drive is always on....ie the platter is always spinning. The local techs either won't touch it, or want $600, which is a bit rich for me right now.
Dillen
Posts 13,191
Dillen replied on Sat, Apr 13 2013 7:21 PM
Is the ruler missing ?
It is an essential part.
If you dismounted it, did you put it back and adjusted it correctly ?
Hitting the off switch at the far right end of travel ?
Switch intact ?
customxke
Posts 7
customxke replied on Sat, Apr 13 2013 8:12 PM
Ruler aligned. Switches intact.
Dillen
Posts 13,191
Dillen replied on Sun, Apr 14 2013 6:35 AM
Hitting the off switch at the far right end of carriage travel ?
All connectors correctly seated at the main board ? They can easily go in one pin off to one side.
Page 1 of 1 (16 items) | RSS
