Hello gentlemen,
thinking it would be nice to also control my PS3 with the Beo5, I just invested in an ORB PS3 remote so I would get an IR dongle as i assumed that I would be able to use one of the PS3 xmls in the download section. However, after having tried the xmls available in the download section I suspect that this dongle use some kind of other IR codes.
Has anyone else got the Beo5 to work with this IR dongle?
Would appreciate some help.
Best regards,
Link to the remote:
http://www.amazon.co.uk/ORB-VT-COMP-GIFT-MAN-Media-Remote/dp/B000A63KWE/ref=sr_1_4?ie=UTF8&qid=1366051684&sr=8-4&keywords=orb+ps3+remote
The Download section
http://beo5.beoworld.org/Downloads.htm
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
I run a PS3 with this: http://www.schmartz.com/products/ps3ir-x1
Works perfect with the Beo5/6. Its not the easiest to use, maybe I need to re-program my Beo5 but controlling dvd's is fairly straightforward.
Good luck! I bought my Schmartz from ebay.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
