Hello, it has been a while since my last thread the beovirus has set in i have since added another MX4000 to the collection. Along with my Beovision 1 which has to be the most beautiful TV I have seen.
My MCP 5000 does not light up properly, I can select the source that I require and the volume, but when I select Bass or Treble a green light comes on the screen but it doesnt light up fully. The screen stays blank when I press the Status button also. Would this be an easy fix i.e something someone with a basic knowledge like myself could fix?
Thanks in advance
Aaron
Hi Aaron,
Did you ever find a fix for your MCP 5000? Mine is struggling to display correctly too - only the vertical blips of red and everything flickers quite a bit.Was looking for some advice with a fix.
Julian
