Hi Beofan53,
to access the files on the BeoMedia via BS5E a DLNA-server must be running on the BeoMedia.
If you can see any from the BS5E or from the Creation app, it already has one installed.
You can't use the NAS (means the server on the NAS) from your BeoMedia.
I can't imagine the BeoMedia acting as a renderer/DLNA-player!
You can only access one server at a time from the BS5E - means: you would have to change the settings every time you want to access the other one.
How about copying your files to the HD of the BeoMedia (if enough space)? You wrote that the HD "is accessable from the Creation-app)
I don't know if this answers your questions?
Greetings Millemissen
You could copy the content from the beomedia to the nas. Then add a folder in your BM-Music folder, which points at the nas.
So, when then bm1 reads its music folder, it actually reads the music on the nas.
