BEOMEDIA 1 an Ouverture
tintenfish
Posts 7
tintenfish Posted: Fri, Apr 19 2013 9:36 PM
Ist es möglich eine Beomedia 1 via Beolink an eine Ouverture anzuschliessen, so dass der ton über die Ouverture ausgegeben wird?
Vielen Dank im Vorraus für tipps und tricks. Habe es bis jetzt nicht geschafft.
BeoHut
Posts 482
BeoHut replied on Fri, Apr 19 2013 10:08 PM
Yes, that is possible.
But, the Ouverture does not understand commands for N.MUSIC and N.RADIO.
Therefore connect the BM1 to the AUX input of your Ouverture. Now the music goes via your audiomaster. Use the audio-out of the Beomedia. I do not know if this would work with Masterlink.
To access files on your BM1 you should install an IR-eye to the Beomedia and possible an other option setting.
You can always use your tv for selecting files. Do not know your configuration @home.
Sorry for answering in English, but that's better than my German.
Page 1 of 1 (2 items) | RSS
