I've received my lovely BNIB Beolink 1000, and it works beautifully, but I can't figure out how to switch the BC8000 to Aux or Tape 2, and given that one is connected to my TV, and the other to my iPod, that's a bind. Anyone know whether it's possible?
AUX is SHIFT then RADIO and Tape 2 is SHIFT then ATAPE
Regards Graham
Tape 2 is SHIFT + A.TAPE.
As I recall you didn't have other B&O kit around, so you might want to solve the TV problem by programming your Beocenter to audio option 2: then it will turn on with AUX selected simply by pressing TV.
(the normal setting is option 1, meaning the Beocenter will only respond to audio commands)
--mika
Thanks, I may do that! I'm pondering whether to look for a Beovision 3 used, or instead to go for a cheap HD flat screen. There's nothing wrong the with TV I have, but it would be nice to control everything from the one remote, but equally, it'd be nice to have HD, and there's no way I can afford a B&O HD set.
