Has anyone tried{seen the new iPad (3) with BeoSOund 8?
Yes, works fine. Not sure if people are aware, but the part that holds the iPad on to the BS8 is adjustable, so you can move it closer/further away, depending on which iPad you own.
I've used the iPad 1, 2 and now 3 in the BS8 so far. iPad 1 was the most stable of them all, but the iPad 2 and 3 sit in there fairly safely and securely after some adjustment.
Thank you for your response. I just ordered iPad 3.
I, too, have 1 and 2 and have complained about the stability of 2 (adjustment notwithstanding)
The next issue is Apples new iPhone 5 when it comes. it is supposedly to have a different dock connector. so your new iPhone 5 won't work with your beloved Beosound 8
I have to doubt the rumors of a completely redesigned dock connector on iPhone 5. This move would instantly alienate tens of thousands of iPhone and iPod compatible products all over the world. Not an intelligent marketing technique for a company that is a brilliant marketer.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Hungedu: I have to doubt the rumors of a completely redesigned dock connector on iPhone 5. This move would instantly alienate tens of thousands of iPhone and iPod compatible products all over the world.
Exactly. And with Apple replacing iPad 2 smart covers - free of charge - for iPad 3 users who complain, it would be a costly business swapping out a dock you recently bought for your iPhone, only to find it doesn't work with an iPhone 5.
Some people speculate and spread fear for no real good or valid reason whatsoever.
It would be disastrous for Apple to redesign the dock connector. I understand that from year (fill in the blanks), all phones are suppose to have the same charging connector making them all universal.
However I'm guessing Apple would just create a new port fitted on the phone.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
"Dad gets an iPad": http://www.wimp.com/dadipad/
In Swedish, but the humor comes thru regardless.
I believe Apple made a commitment to manufacters of 'dock' products that they would not change the connector for a minimum of ten years.
The manufacturers of 'dock' products should just do like Apple -make new versions of their docking stations every year (it's only a matter of marketing)
Chris Townsend:All phones in the EU should have a mini USB port. Should. Apple have an adapter (£8) that does the job.
The regulation on the micro USB port only concerns the charging. It says nothing about how & where the analog or digital audio signals or any other control is implemented. Mini USB has been mandatory in phones in China since 2007.
Apple will change the interface whenever they see fit and the fans will still run screaming to buy the new products.
--mika
tournedos: Apple will change the interface whenever they see fit and the fans will still run screaming to buy the new products.
...............and will claim it to be a unique, innovative and exciting new feature!
Ban boring signatures!
Found this and thought it was funy -
I also have all versions of iPhone. Do you suggest sepuku?
Lanny: I also have all versions of iPhone. Do you suggest seppuku?
Puncher: Lanny: I also have all versions of iPhone. Do you suggest seppuku? .................. if only they'd release an iTantō!
