Mystery Item Competition Time!!!!
This post has 14 Replies | 1 Follower
beaker
Posts 761
beaker Posted: Mon, Apr 22 2013 3:25 PM
Ok everyone I recently discovered some items in there boxes, totally unused new old stock and had absolutely no idea what they were when I first took one out of its box. If you can ID it you can have one, free of charge! Dont get excited, they are not worth anything (I'll be gutted if I give them away and then see one go on ebay for £50!!)and not really much use but its fun doing this anyway. Oh and the product info pages will not help.
To show the size, heres one of the boxes
And heres a sneaky one of the item.
Guess away!!
Dennis
Denmark
Posts 627
Dennis replied on Mon, Apr 22 2013 3:27 PM
It looks like a table bracket for a link eye - The old MCL type! Smile
- Dennis
EDIT: I think they were mainly used with the VX Sensor (Link to BeoCentral).
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Apr 22 2013 3:42 PM
Best regards
Ralf
beaker
Posts 761
beaker replied on Mon, Apr 22 2013 3:58 PM
OK, that obviously wasnt as hard as I thought! It is indeed a Table top mount for an MCL transceiver.
Does anyone want one?
I'll have a look and see if I have anything else to photograph thats a bit odd or maybe Ralph or Denis could put an item up.
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Apr 22 2013 4:09 PM
This IS ODD - if you know what it was used for...
Ralf
PS: beaker, thanks for your kind offer, but I don't need the table-top mount (should have one myself, somewhere....)
beaker
Posts 761
beaker replied on Mon, Apr 22 2013 4:22 PM
Is that an ir code convertor so the BL1000 can be used on earlier stuff like the BM8000?
Heres another wierd thing
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Apr 22 2013 4:27 PM
kallasr:
Ralf
Isn't that the external IR sensor for the BM5500, for those who stick it in a cupboard?
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Apr 22 2013 4:39 PM
Guy:
Yes! Used to HIDE (!) your nice B&O stuff...
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Apr 22 2013 4:45 PM
I only knew because MJBeo was after one a while back: http://archivedforum2.beoworld.org/forums/p/5123/46088.aspx#46088
Never heard from him - and I don't think the Lifestyle sensor was the right one because the pin arrangement was different!
Langleyav
Windsor UK
Posts 226
Langleyav replied on Mon, Apr 22 2013 5:13 PM
That looks like an LNB 22khz add on to allow older satellite receivers to use a dual band universal LNB
Ron
Langleyav
Windsor UK
Posts 226
Langleyav replied on Mon, Apr 22 2013 5:15 PM
Dual posting
js
Posts 382
js replied on Mon, Apr 22 2013 9:17 PM
beaker:
Hi beaker,
If you are asking, well, I would LOVE to have one. Can we arrange that? Many thanks!
js
MJBeo
Netherlands
Posts 270
MJBeo replied on Fri, May 3 2013 9:02 AM
[edit: double entry]
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
MJBeo
Netherlands
Posts 270
MJBeo replied on Fri, May 3 2013 9:03 AM
Guy:
found a perfect one in Estonia, will be trading it. The livestyle one was indeed not the right one. Cheers though!
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, May 3 2013 9:04 AM
No worries - glad that you found what you wanted and thanks for letting me know!
Guy
Page 1 of 1 (15 items) | RSS
