Beogram 1202 - no signal, no sound ?
This post has 7 Replies | 0 Followers
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Thu, Apr 25 2013 2:12 PM
hi everyone,
just purchased a 1202 in good cosmetic condition but I can't seem to hear anything.
as far as I could see everything seems to work mechanically fine - all arm wires are attached
no cable broken - tried with two different cartridges ....but no sound to be heard !
any suggestions or ideas are most welcome
cheers, alf
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Thu, Apr 25 2013 2:36 PM
Does your reciever/amplifier got a RIAA-pre amplifier?
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Fri, Apr 26 2013 2:22 AM
greetings,
I am using two Braun R4/2 receivers, both come with phono-inputs offering either RCA or DIN connectors
 cheers, ALF
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Apr 26 2013 7:25 AM
Is the stylus tracking the record correctly ?
Søren Mexico
Mexico City
Posts 6,411
Dillen:
And if yes, Does the Braun use the same pin connection as the B&O 5 pin DIN, and check the muting contact in the 1202.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sat, Apr 27 2013 2:20 AM
hi martin,
first thing: the cantilever seems to be in a fairly low angle, so the stylus tip does just look out of that transparent plastic bit ?
it is an SP-10 - on my SP-14 the cantilever angler is a lot bigger and when the arm is lowered the stylus sits correctly in the groove.
to sum up: I suspect the suspension of that SP-10 system is damaged.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sat, Apr 27 2013 2:24 AM
so soren,
the DIN 5-pin plug seems different - I did use a DIN-RCA adaptor and surprise....the signal was there :-)
had to use an additional piece of wire to eliminate the hum though !
next project in line is to figure out the tracking force and antiskating adjustment as that little turning knob on the arm's right side came undone
as it is spring-loaded I am stepping totally in the dark after pushing it back in what I am actually adjusting in terms of force ??
cheers, klaus
Agent00soul
Posts 15
You set the knob to "0" and then turn the counterweight until the tonearm balances in mid-air. Then you set the knob to the desired needle pressure.
Page 1 of 1 (8 items) | RSS
