Dear members,
how to you connect speakers to a Beosivion Avant in a surround setup? Do you only connect one of the front speakers to the TV and then link speakers or do you connect both speakers directly to the TV? What about the rear speakers? Does connection make any difference at all? Both means are described in the manuals...
Thanks!
Rgds,
Kai
Either is the answer. If the surround module is fitted, then it will have two front powerlink sockets, two rear sockets and one for a sub-woofer. You can either connect each speaker to the TV or you can daisy chain e.g. from the TV to the first front speaker and thence to the other front speaker. What you cannot do is daisy chain from a front speaker to a rear speaker. Each powerlink socket contains information for both right and left channels - there are no audible differences between the two methods.
Peter
BeoNut since '75
Thanks very much. But it would be possible to daisy chain fronts and directly connecting both rears? This forum is really of so much help. I feel bad for asking so much, but it's really helped me a great deal. Thanks so much, everybody!
You can certainly daisy chain the fronts and directly connect the rears. The secret to understanding powerlink is that each socket contains information for both right and left channels so daisy chaining or direct connection will make no discernible difference. One could argue the speaker furthest away will have a delay but as the signal is travelling at the speed of light, the change in angle of the head will have an effect which massively outweighs this!!
The subwoofer question is another interesting one. The internal circuitry of the subwoofer filters the lowest frequency away from the front speakers if they are attached to the subwoofer. However selecting the subwoofer channel should have an effect in itself.
I'm not entirely sure, whether I do understand this comment correctly, BeoHut. So, you are saying that daisy chaining fronts and rears will make me loose 5.1 even when connecting the sub directly to the TV? Sorry for asking, but what do you mean by writing "daisy chain from a sub"? I was only thinking about directly connecting the two fronts and the two rears.
Thanks once again!
