BEOCENTRE 9500 DISCONNECTED NOW WONT POWER UP
ALANPENNINGTON
Posts 5
ALANPENNINGTON Posted: Mon, Apr 29 2013 2:21 PM
CAN ANYONE HELP........PLEASE!
 I HAVE HAD MY BEOCENTRE 9500 DISCONNECTED FROM THE MAINS FOR THREE WEEKS DURING GUTTING MY LIVING ROOM. WHEN I HAVE RE-CONNECTED TO THE MAINS AT FIRST IT CAME UP WITH CO.DE ON THE RIGHT HAND SIDE OF THE DISPLAY AT THE TOP. NOW CO.DE HAS GONE BUT WONT GO TO STAND BY, IF I PRESS THE NO.7 ON MY REMOTE THE VOLUME COMES ON AND SOME OTHER LIGHTS BUT DIES AGAIN AFTER APPROX 5 SECONDS.
I HAVE BEEN TOLD IT NEEDS A NEW INTERNAL BATTERY AND THE PROCESSOR RE-PROGRAMMING...........IS THIS CORRECT.
SOMEONE ELSE HAS SAID THAT THERE IS A SERIES OF BUTTONS YOU PRESS TO RECONFIGURE THE SYSTEM WHICH TAKES SECONDS TO DO
BeoHut
Posts 482
BeoHut replied on Mon, Apr 29 2013 2:25 PM
No panic! Just replace the battery or leave it on the mains.
You can find your code here: http://www.beoworld.org/faq_view.asp?id=76
ALANPENNINGTON
Posts 5
MANY THANKS BEOHUT, I WILL LET YOU KNOW IF IT WORKS..........AGAIN THANKS.
ALAN PENNINGTON
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I can't find a faq for your problem but this thread may be of some help
http://archivedforum2.beoworld.org/forums/p/4674/43242.aspx#43242
Regards Graham
ALANPENNINGTON
Posts 5
HI EVERYONE.....................THE CODE WORKED A TREAT...........MANY THANKS TO GRAHAM & ALSO BEOHUT
ALANPENNINGTON
Posts 5
IF I DON'T REPLACE THE INTERNAL BATTERY BUT LEAVE THE 9500 IN STANDBY WITHOUT POWERING OFF FROM THE MAINS WILL THE 9500 KEEP ALL RADIO STATIONS OR WILL I HAVE TO FIND ALL STATIONS AGAIN & AGAIN.
ALTHOUGH I MANGED TO GET THE 9500 POWERED UP AFTER BEING DISCONNECTED FOR ABOUT THREE WEEKS BY USING THE REMOTE TOGETHER WITH A CODE ON THE REMOTE THE 9500 DOES NOT SEEM TO FIND (ONLY ONE OR TWO) RADIO STATIONS BY SEARCHING, DO I NEED TO CLEAR ALL WHAT IS PROBABLY IN IT'S SCRAMBLED MEMORY BY USING THE "CLEAR" BUTTON..........CAN SOMEONE TALK ME THROUGH FINDING & STORING THE STATIONS (MY MANUAL HAS LONG SINCE BEEN LOST IN HOUSE RE-DECORATIONS ETC.)
REGARDS
ALAN PENNINGTONBig Smile
BeoHut
Posts 482
BeoHut replied on Tue, Apr 30 2013 5:19 PM
See the explanation in your other thread. Enjoy your BC!
tamtapir
Örebro, Sweden
Posts 521
tamtapir replied on Tue, Apr 30 2013 6:17 PM
ALANPENNINGTON:
Please, push
Søren Mexico
Mexico City
Posts 6,411
tamtapir:
ALANPENNINGTON:
Please, push
NICE PIC
Page 1 of 1 (9 items) | RSS
