Connecting Beovision 3 to Airport express
This post has 3 Replies | 0 Followers
Bundy
Posts 67
Bundy Posted: Tue, Apr 30 2013 8:50 AM
HI
How can i connect my Beovision 3 to my apple express? I wan´t to hear music via the speakers in the Beovision 3.  I have tried with a Beolink Video but it don´t work. Is this the way to go?
Peter
Sweden
Posts 84
Peter replied on Tue, Apr 30 2013 9:13 AM
Hi Bundy,
The easiest way is probably to connect it to one of the 3 Scarts.
Use a 3,5 m.m. to RCA cable and attach the red and white RCA to a SCART adapter..
Another choice is of course to use an Apple TV so you get full advantage of allocating one of the SCARTs.
A second hand Apple TV 1st. generation is easily hacked with ATV Flash to be able to connect directly to scart without any extra converters. Then you get both sound and picture and more fun for the same price.. :)
Good luck!
/Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Bundy,
the easiest way is to connect the APE to R/L of the close-up socket panel.
If you don't use the AV-socket, you could use a scartadapter with analog R/L input..
Or use the digital input 1 (AV-socket) and a 'toslink to spdif-converter'.
If the tv is in 'Option2', you can use  the command 'AV' before the 'Source' to get sound without turning on the picture.
Please consult the userguide of the tv.
Greetings Millemissen
Bundy
Posts 67
Bundy replied on Wed, May 1 2013 7:08 PM
Thanks for your replys. I think i will use the frontsocket solusion.
Page 1 of 1 (4 items) | RSS
