hello
i have a problem with burning CD on my BS9000.
if the originals CD are allways OK, i have problems with burning CD-R.
sometime the CD-R is OK and start, sometime the same CD spin very fast and stop and re-spin and stop and run....
i burn CD at low speed, fast speed blue CD-R (AZO) and other but sames problems.
the very strange is that sometime the same CD-R run and 1 hours after this same CD don't run..
do you have already the same problems ?
Probably it's soon time to change the laser pick-up.
//Bo.A long list...
Thank you for answered.
the laser whas changed 5-6 years ago, because the original CD doesn't work and i have allways this problem.
