I used 'dsaudio' a couple of times - my NAS is also a Synology.
And never again. Use PlugPlayer, 8Player, Creation5, if you are a iOS-user!
N.B. I did not understand all, that was written above, but these are my 2 cents!
Greetings Millemissen
And how do you gain access to the dsaudio/synology WITHOUT an iOS-device?
And what do you mean by "autonomously"?
Hi Leufje,
When you connect to audio station on your synology via a web browser (via a computer, not an iDevice), are you able to see "Playmaker" on the device list (by default, the item is "my computer". And there is even a "multiple airplay devices" on the list... If it doesn't appear, then the DS412+ (I have the same NAS) doesn't "see" the playmaker...
diisign.com
That is exactly what every DLNA software does..
...lets you connect a server to a renderer.
1: the iOS device is renderer/player AND control point as well - to get sound send to your PM you must use the AirPlay function (of the iOS device and the PM) (= AirPlay function of the PM)
2: the iOS app (or webbrowser function) is nothing but the control point. - the sound is send from the server to the renderer/player (the PM) direct. Every DLNA app can acts this way! No AirPlay is involved! (= DLNA function of the PM)
There are several reasons, why I choose not to use the DS audio app.
Mainly because I do not like the interface - but also because I want to be able to pick a server of my own choice.
You may install different servers on the SynNAS - most of them are better than the one used by DS audio.
Try different servers/DLNA app's and choose the combination you like.
mbee:Hi Leufje, When you connect to audio station on your synology via a web browser (via a computer, not an iDevice), are you able to see "Playmaker" on the device list (by default, the item is "my computer". And there is even a "multiple airplay devices" on the list... If it doesn't appear, then the DS412+ (I have the same NAS) doesn't "see" the playmaker... diisign.com
The cuts in the rendering could be a problem with wireless bitrate : are you wired or wireless between DS and PM?
And hare you experiencing this issue both in DLNA and AirPlay?
mbee:The cuts in the rendering could be a problem with wireless bitrate : are you wired or wireless between DS and PM? And hare you experiencing this issue both in DLNA and AirPlay? diisign.com
seems I'll have to update my DSM to the brandnew version - or in my case I should rather upgrade my NAS
You are right, the new DSM now supports AirPlay directly from the SYN via the DSM-interface.
This means that you will have to have a pc/mac running (or could this perhaps be done in the browser of an iDevice?). I prefer using my iPad since it is more flexible, mobile and faster!
Of course the PM will then show up as two different devices with the new DSM.
The great thing about the AirPlay support however, is that you now can use an AppleTV as player!
Right now I am wondering which formats are supported in the Audio Station - if FLAC is not, it's a nogo for me.
You can easily run a Logitech Media Server on the SYN-NAS - which is what I do - it gives you great format support and shows your coverpics in high resolution on the iPad.
But - allthough I did not understand all of your first post - i have a feeling that there were several other issues (PM and speakers not turning off....), which are unanswered.
If you could sum these issues up in english, it would be nice.
