Can someone give me a hint on this problem. One of my Beolab 6000 intermittently starts to do a clicking noise very quickly. I can see the power led flickering at the same time. I have tried to remove the audio source, same problem. Changed the power cord and also used another wall outlet, same problem. So it is something with the loudspeaker itself.
Best regards,
Check the standby relay if changing cables does not help
