iOS Beoplayer Software
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Mon, May 13 2013 2:00 PM
Hello,
Is there a way to stream Internet Radio from the Beoplayer Software to more than one device? I have a Airport Express and an Apple TV in two corresponding rooms and yould like to have some kind of multiroom streaming.
Thanks!
Heribert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Millemissen
Flensborg, Denmark
Posts 14,680
Hallo Heribert,
not that I know!
But you could connect the AirPort Express to a ML-BeoMaster and link as many rooms as you like.
But you probably know that already.
Greetings Millemissen
BeoHut
Posts 482
BeoHut replied on Mon, May 13 2013 5:25 PM
With the Aple devices you can via Airplay select only one source. But for streaming in multiple rooms you can use a separate iDevice for room 1 and another iDevice for room 2.
As Millemissen suggestested it is easier to integrate it in a ML-setup. Even without conflicts!
peria
Posts 321
peria replied on Tue, May 14 2013 5:08 AM
Do ou have a Mac? iTunes can stream to multiple Airplay devices, including Playmaker. If you want to listen to Spotify, Pandora, etc., just add Airfoil. If you also want remote from iOS, add Reemote. Now you have multiple distribution points. Almost like ML.
Heribert
Posts 804
Heribert replied on Tue, May 14 2013 7:56 PM
Thanks for the support. I used to use ML with a BM1, but with the BV11 this became obsolete.
I do have a Mac, but tried to use the IPod as streaming device. Seems this is the limitation.
Page 1 of 1 (5 items) | RSS
