I have a BC9500 connected to BV3 via BeoLink Converter 1611, plus an MCL link room.
I have just set up an additional ML link room using a Passive. It works fine, but will not activate on the Timer function - i.e when the timer is set on the BC9500 and also selected on the ML IR puck.
I've checked all the Option settings and have unplugged and reconnected but it still will not work. In addition, the TV does not come on even when I activate its timer. The BC9500 and MCL room timer functions work fine. There's seems to be a problem between MCL and ML - any ideas?
