Using LC2 for opening/closing blinds
This post has 0 Replies | 3 Followers
kokomo
Spain
Posts 206
kokomo Posted: Tue, May 21 2013 3:30 PM
Can someone please tell me if an LC2 could successfully function in the following way?
I have a chance to obtain a complete vertical blind assembly which is motor driven (close/open) with a 12v powered mechanism via a mains adapter. To close all that is necessary is to switch the power on to the adapter and the blind closes and at the end of its travel it stops. To open, the power is switched on again at the mains adapter and the motor drives the blind back to its original position.
Would it be feasible to utilise an LC2 for this and perhaps devote one number (for example #9)  for this purpose only and switch on/off/on?
I've explored some other options and the LIntronics method seems an expensive option as do others. Anyone any advise or suggestions please? Or should I forget the idea?
Thanks.
Page 1 of 1 (1 items) | RSS
