Works with mine. I am on 10.8.3.
Peter
Erik_2D00_nl:Thanks Peter, what software are you using ?
BeoNut since '75
Peter,
I am using OSX 10.8 and Itunes 11.
I do not find the link to LINKPLAYER V1 so I can test it and I thought to have heared that BMlink did not work with the newest Apple software?
I would use the "beoport" in a seperate office - but hope for a possibility to link other sources between the Beoport and the mainroom
Erik-nl:I do not find the link to LINKPLAYER V1
https://www.dropbox.com/s/bor6hyez6y32178/LinkPlayer.app.zip
install and run so you can complete the payment to PhilLondon
or try BMLink first see it is free
I use BM Link and an iPhone as a remote for iTunes. Works fine - just upgraded iTunes to the latest incarnation and still works.
