Avant DVD controller problems
This post has 9 Replies | 2 Followers
Eugenio
Italy
Posts 15
Eugenio Posted: Fri, May 24 2013 10:09 AM
Good mornig
I have a little problem with my DVD Avant Controller; before recapping wasn't able to read the DVD TOC, after recapping it reads dvd, start executing but after a couple of minutes the image freezes and the controller starts to jump over dvd chapters. Tried using a cooler spray over the IC on the pcb but nothing change. I have no idea what to do and a new controller costs much more the whole set itself.
Could someone give son hints? I exchanged the controller with another from Philips donor but it seems to be an "autentication code" by the controller and B&O interface PCB.
I have no idea how to solve the problem :(
Regards in advance to all the helper :)))))
Eugenio
Michael
Sweden
Posts 2,578
Michael replied on Fri, May 24 2013 2:52 PM
NoBit:
Good mornig
Eugenio
What did you change? Which capacitators? I have bought a few lasers for the Avant and I am just in the project of replacing one :) Perhaps I should have a look at the electronics also?
Eugenio
Italy
Posts 15
Eugenio replied on Fri, May 24 2013 6:19 PM
Hi Michael
I replaced all capacitors in the controller board (also called MONO board); there is no reason to replace them if the unit works correctly. :)
Michael
Sweden
Posts 2,578
Michael replied on Sat, May 25 2013 12:04 PM
NoBit:
Hi Michael
Hi NoBit,
I did not even think about doing that. Is it one of these boards that you mean?
Eugenio
Italy
Posts 15
Eugenio replied on Sat, May 25 2013 1:25 PM
Number 2 is the controller
Michael
Sweden
Posts 2,578
Michael replied on Sat, May 25 2013 1:28 PM
NoBit:
I´ll take a look at it today. Did you have bulging capacitators on yours? I have two Avants so I should have a look :)
Eugenio
Italy
Posts 15
Eugenio replied on Sat, May 25 2013 1:53 PM
No I didn't. Consider that the bulging surface is the LAST step of a capacitor decadence. Before that there is a value variation and internal resistance increasing value.
ciao ciao
Eugenio
Eugenio
Italy
Posts 15
Eugenio replied on Sat, May 25 2013 1:54 PM
Maybe you have a dvd controller for me :)
Michael
Sweden
Posts 2,578
Michael replied on Sat, May 25 2013 2:05 PM
Thanks for the info! :) I am not super familiar with the electronic components on the boards but I try :).
I have two units because the first DVD failed, and now I try to fix it so I can sell it or use it in another location. The new one is also starting to behave a bit odd on DVDs.
I did order a few lasers and I think that the problem lies in the laser at least partly. You seem to have had success replacing the caps but perhaps that is not all that is necessary.
Eugenio
Italy
Posts 15
Eugenio replied on Sat, May 25 2013 9:03 PM
You are welcome!
Page 1 of 1 (10 items) | RSS
