Beolab 3500 queries
blidge
Posts 11
blidge Posted: Mon, May 27 2013 9:20 AM
I have a Beolab 3500 that I wish to wall mount. The piece of the mount that fits to the wall is missing and despite searching high and low I can't find it. I definitely had the part but the law of Sod dictates it won't show up until I buy a replacement!
Does anyone know how much a dealer in the UK charges for this part or better still does anyone have a spare they wish to sell?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Mon, May 27 2013 10:49 AM
Hi Blidge, you have an email.
Opman
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Parts used for the BeoLab 3500 wall bracket consists of 2 or 3 main parts depending on placement.
  • The part onto which you mount the BeoLab 3500 is part number 3031300
  • The part which is mounted on the wall is part number 3031200 and where the BeoLab 3500 mounted on the above bracket slides onto has screws with part number Part number 3390481
  • For light partition walls and always used in US the bracket with a larger surface  has part number 3031302 onto which the above bracket is mounted. The part number for the screws for this bracket is 3390468.
I have not purchased this bracket recently, but as it is considered a spare part I would expect it to be quite reasonable.
Regards Keith....
blidge
Posts 11
blidge replied on Tue, May 28 2013 10:05 AM
Thanks for the info guys.
Page 1 of 1 (4 items) | RSS
