Recommendation for a new router
This post has 12 Replies | 1 Follower
badgersurf
Posts 539
badgersurf Posted: Wed, May 29 2013 3:27 PM
I am looking for a new router with wifi extenders (as my house has solid brick walls and wifi does not seem to travel that far through the house.
My old one has died plus the extenders all seemed to set up different zones, they were all set up to the same network passwords etc but my Beolit 12 did not seamlessly move between them and I had to use the app to join a new netwrok when I move from one area to another.
Does anyone have any recommendations?
Toby
peria
Posts 321
peria replied on Wed, May 29 2013 4:12 PM
I also have a house with very difficult wifi issues. I have use an Apple AirPort Extreme, with power line Ethernet, to the most difficult areas. From those distant (wired) points it is possible to have additional wifi. It was the best I could do without investing $2000-3000 in wiring. It works.
Lars
Munich
Posts 146
Lars replied on Wed, May 29 2013 4:39 PM
As far as I know the issue with WIFI is that it is not possible to "change networks", even extended ones without a proper reconnect.
BS9000, BC6, BC2, BL3, BL11, BL3500, BL2000, BeoTime, Beo EarSet2 3i, Beo, BEO DropStop, BEO Bottle Opener, BeoCom5 including Table Stand, ATV
Christmas Prize Draw 1st Winner 2010 - THANKS A LOT!!!
Struer Trip 2012 - THANKS A LOT!!!
StUrrock
Posts 995
StUrrock replied on Wed, May 29 2013 5:07 PM
For the ultimate we install a wireless mesh system in large properties. Can be expensive.
Recently on a large install (Playmakers all hard wired) we installed this router non WiFi version:
http://www.draytek.co.uk/products/vigor2820.html
With this single Access point:
http://www.ubnt.com/picostation
Great range and worked a treat :)
With regards BeoLit 12 I'll have a go at working out something.
Fl_ip
Posts 160
Fl_ip replied on Wed, May 29 2013 9:04 PM
We use a lot of the Unifi series also. Normally the Unifi Pro
StUrrock
Posts 995
StUrrock replied on Wed, May 29 2013 9:37 PM
Fl_5F00_ip:
Great kit sshh don't tell everyone ;)!!!!!
synth
Off piste
Posts 105
synth replied on Thu, May 30 2013 1:35 AM
I am not a wifi fan - anything that bathes people in microwaves is inherently dangerous.......
In your case the simplest option could be buy a Hilti masonry SDS drill and some long masonry auger bits ( say 12-24 inch ) and drill through walls and run some 1 GB Cat 6A cabling and buy a 1 GB 5 port local ethernet switch and run a wired  wired connection to either another wifi unit/repeater, or just plug into the cable directly.
Simple = robust.
rxcohen
New York
Posts 201
rxcohen replied on Thu, May 30 2013 5:12 AM
How large is your coverage area? If AirPort Extreme with extenders won't work, it may be simpler to invest in a business grade solution such as Cisco 541N router with built in wifi. There are also other options with business grade access points which should provide good coverage for about 2500-3000 square feet.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, May 30 2013 12:58 PM
Apple are shortly bringing out a new more powerful router that's meant to be good - I use a couple of  airport express to extend my network wirelessly as the building is around 250 years old with thick walls. It works really well with no drop out when moving from one zone to another and streaming music from my iPhone.
badgersurf
Posts 539
Thanks for all the advice, will look at all the suggestions and work out which one suits my needs best.
I plan to wire the house with cat7 cables which will over the ML, PL, and ethernet, and then have wifi for my ipad and the beolit.
Toby
fishta
Posts 27
fishta replied on Thu, May 30 2013 4:37 PM
I have had a Draytek 2820n for the last 3 years and never had to reset it. I used to have it connected to BeThere ISP and now have it connected to a Virgin Media Super Hub in modem only mode and it runs fantastically.
kuyttendaele
Posts 707
Since a week I installed a Linksys Smart Wi-Fi Router EA6700... which replaces the Linksys EA4200... I never experienced any dropouts with the 4200 but the reach of the EA6700 is far better.. and is 802.11ac (draft!) compatible...
Internet connection at home is 120Mbit down/5Mbit up.
http://www.linksys.com/en-eu/products/routers/EA6700
synth
Off piste
Posts 105
synth replied on Fri, Jun 7 2013 4:53 AM
You might want to look at Cat 7A  to give yourself more room to move. I believe B&O are moving to at least Cat 7 in the future for their networking.
With the extra work in doing cat 7<x>  variant cabling, it could be worth it.
With the unreliability with wifi, keeping it local ( within 2-5 m ) will improve chances of decent performance. Asking RF to work well through walls is like trying to spray water through a fly wire screen.....messy and fairly unpredictable.
Have fun....
Page 1 of 1 (13 items) | RSS
