BL7.1
Langleyav
Windsor UK
Posts 226
Langleyav Posted: Fri, May 31 2013 11:38 AM
I have a small dent on the front grill of my BL7.1. Is there anyway to remove the grill so that I can press it back into shape from it's rear.
Ron
olvisab
Posts 1,391
olvisab replied on Fri, May 31 2013 11:44 AM
Hello
I have a bl 7.2, you just have to slide it to the left.There are no screws.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, May 31 2013 4:51 PM
The technique is to just gently tap the right end of the grill with your right hand. It should slide to the left and lift off. Once it is off it may be possible to push the indent back out again.
To refit simply align the grill off set to the left and slide it back on to the lugs on the speaker.
Sounds odd when describing it like that but once you have done you will realise how easy it is.
HOWEVER make sure that the grill is the right way up when you re fit it. If it is upside down and you force it on, they are very difficult to get off again Whistle
Opman
Millemissen
Flensborg, Denmark
Posts 14,680
In my experience it is not easy to 'make the dents disappear'.
You can make them smaller, but ofter you will still see the 'mark'.
Best avoid making the dents!
Those with big dog have to take speciel care - the grills are not 'dog tail friendly' 🐶
Greetings Millemissen
olvisab
Posts 1,391
olvisab replied on Fri, May 31 2013 6:03 PM
Millemissen:
This is just your "cat" opinion. ;)
Millemissen
Flensborg, Denmark
Posts 14,680
Miaw 🐱
Page 1 of 1 (6 items) | RSS
