2-way + RDS?
This post has 7 Replies | 2 Followers
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Ƨcɑɽɑɱɑnɡɑ Posted: Wed, Mar 28 2012 2:02 PM
Besides the BM7000, what other Beo had both 2-way AND RDS?
Thanks!
  • One B&o bottle opener
  • One fancy gun
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Mar 28 2012 2:32 PM
MPAV9000 with AV9000.
Early Beocenter2300 with RDS kit.
And maybe Beocenter2500...
Stefan
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Mar 29 2012 2:42 PM
I'm sorry but the BeoCenter 2500 doesn't offer RDS on the Beolink 7000 even if the BeoCenter itself has the RDS installed and working.
And i think even the Beocenter 2300 with RDS Kit and 2-Way Software doesn't send RDS Info to the Beolink 7000. Both can be programmed to use a timer for play, record or standby but they can't control light Crying  (That's what the Beocenter 9500 can do, it's also 2-way capable, but no RDS info for the Beolink 7000).)
For the Beovision 9000 and the MPAV i also doubt whether it sends RDS Info but i'm not sure.
So this only leaves the 7000 as sending RDS Info to the Remote Control.
RaMaBo
Ralph-Marcus
henrik
Sweden
Posts 458
henrik replied on Thu, Mar 29 2012 5:08 PM
RaMaBo:
Sorry for hijacking the thread, but since you mentioned the 9500's timer capabilities: Is it possible in the 9500 to program timer events such as "switch on radio every sunday morning but keep quiet other mornings" (as in the 7000) or is it only a 24 hr timer?
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Mar 29 2012 5:18 PM
henrik:
I just checked and the answer is yes: you can create a weekly timer, and then pick up any combination of weekdays (or just one) to include in it.
Annoyingly it requires you to input a switch off time as well, but I guess that's seldom a problem.
--mika
stefan
Posts 2,920
stefan replied on Thu, Mar 29 2012 5:30 PM
RaMaBo:
RaMaBo
Agree completely. But the OP didn`t ask about Beolink 7000. It was a simple question about Beomasters supporting two-way communication AND RDS.
BTW I can confirm that the MPAV9000 doesn`t send RDS info onto the BL7000 display.
Stefan
henrik
Sweden
Posts 458
henrik replied on Thu, Mar 29 2012 5:35 PM
tournedos:
Ah,  just like the 7000 then! Great!
As I mentioned in another thread, I bought a 9500 to check whether my sound quality problems was caused by my bm7000 or my Pentas (it was the bm7000, btw), but after checking that I went back to the 7000 again since it has quite a lot of timers programmed (it actually controls nearly all of the lights in my apartment). I didn't know that the 9500 could do weekly timers, so I didn't realise that it was able to replace my 7000 100%:)
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
stefan:
Indeed, but the use would have been with a BL7000.
So, it looks like I need to find a BM7000!
  • One fancy gun
Page 1 of 1 (8 items) | RSS
