beosound 5 encore
This post has 1 Reply | 2 Followers
greece78
Posts 1
greece78 Posted: Sat, Jun 1 2013 11:30 PM
Artwork does not always copy over to Beosound 5 encore. is there a way to add it
BeoHut
Posts 482
BeoHut replied on Sat, Jun 1 2013 11:56 PM
If you have your coverart embedded in the musicfiles, reboot your Encore and do a new scan for musicstorage. After a while the covers will show up. No need to make a special file called folder.jpg .
Are you using a pc or mac for ripping files? Several free software is available for both platforms. Most common use are flac and wma-lossless files for the best performance.
Page 1 of 1 (2 items) | RSS
