Mac adres
This post has 4 Replies | 3 Followers
sl
Posts 22
sl Posted: Wed, Mar 28 2012 6:39 PM
Hi everyone,
Where can i find the mac adres of the beo6?
Regards,
sl
Barry Santini
New York
Posts 543
Get into your router (login) and look at "attached devices."  Your MAC address will be listed there.
sl
Posts 22
sl replied on Sat, Mar 31 2012 7:48 PM
Thanks al lot!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Apr 15 2012 6:12 PM
Press standby and the Go button on the Beo6.
Then go to Beo6 info. There you will find the MAC address.
If it isn't listed there (0.0.0.0), then first you have to make contact with your acces point from your router.
sl
Posts 22
sl replied on Tue, Apr 17 2012 6:59 AM
I discovered that both buttons “info beo6” and “server ip” are invisible. By pressing on the please where the buttons should appear, the needed information is displayed. Do you know why these buttons are invisible?
Firmware version: 4.3.4
Page 1 of 1 (5 items) | RSS
