Sometimes while listening to my BS1 (bought in 2003), the volume level decreases to 00 (no sound). This has been going on for many months. I called B&O services and they said there is a contact problem with a part and I need to replace that part, which costs some US$200.
Is there something that I can do myself that would fix or alleviate the problem?
(My BS also has problem with the laser head. If I replace both laser head and the above part, that would cost some $450 and I am not sure that is worthwhile.)
