Hi Everyone,
I have an Avant 32 DVD TV, Beolab 6000 speakers and a Beosound 3200.
Everything was working fine until I moved the system to another room. I used a couple of new connector cables as the previous ones have been left burried under the floor. But otherwise, I haven't messed with the system.
Anyway, the problem:
When I watch TV, the sound only comes out of the speakers of the Avant TV. But when I watch a DVD, the sound only comes out of the Beolab 3200 speakers. I would like the sound to come out of both the TV and speakers like I think it did before.
Can anyone help me please.
Thank you,
John
Do you not have the set-up manual with your Avant? This is available to silver and gold members on this site.
Press list on your BEO4 remote until 'speaker' is showing. Press numbers 1-5 depending on which speakers you wish to use. Some DVD's have information regarding which speakers the TV should use encoded on them. It shouldn't be a cabling or connector issue. Try this to check all of your cables and speakers are operating OK. Have you plugged your speakers into the same outputs they were in before you moved the TV?
Best of luck.
Dave.
Hi John,
To understand your problem correctly, could describe your installation please:
Do you have the BL6000 conected to the Avant or to the BS3200?
To achive the solution you would like to have you should connect the speakers to the Avant and no speakers to the BS3200.
The set Avant to V.Opt 2 and BS3200 to A.Opt 0. When playing video content the speakers of the Avant (center) and the BL6000 (L/R) are active.
When playing music only the BL6000 (L/R) will play
hfat
Thank you, much appreciated.
