3404 not responding to remote function on Beomaster 2400 remote
sstarnes
Austin, TX , Amalfi Coast
Posts 15
sstarnes Posted: Wed, Jun 5 2013 1:53 AM
Hey all, new user here- just got a beogram 3404 to match my long standing 2400 receiver...
However, I am disappointed to find out that the remote function does not seem to be working:
I press the "P" on the beomaster 2400 remote, and the 3404 does not que the record...
Any thoughts?
Steve
Austin, TX
Beobuddy
Utrecht, The Netherlands
Posts 3,972
First thing I would check is the din plug. Are all wires properly connected and clean/not oxidated and not broken from the pins. You can only check by taking the plug apart.
sstarnes
Posts 15
Thanks, will do.
sstarnes
Posts 15
Looked at the DIN pin on the 3404: Only has 5 pins, should be 7 pins...There are 2 pins missing - I am told these pins are screw in, and very hard to find,,,
sstarnes
Posts 15
sstarnes replied on Wed, Jun 12 2013 7:19 PM
Found and installed the pins.
Turntable remote function is now working
Thanks,
Steve
Page 1 of 1 (5 items) | RSS
