I am moving house . At the new house I have been offered the Beovision 7 - 40 mk 11 7-2 for the price of £3000 . It was installed in 2006, is wall mounted and looks in perfect condition. It does not have hdmi connectors, but I am told it is HD .
Is this a good deal, or has B and O moved forward so much that I should consider buying new?
Any advice would be gratefully received!
If you check our sponsor (Lifestyle AV) you will see that you can buy a more recent HD 7 40 Mk3 for less:
http://www.lifestyle-av.co.uk/details.asp?sectionId=1&productId=8113
I'd knock him down - what is he going to do otherwise?
Dave.
Unfortunately its only worth half that at £1500 max and thats only because of the speaker.
Thank you for all your input. Very much appreciated.. Will get haggling!
