MCP 5500
Wouter
Netherlands
Posts 302
Wouter Posted: Wed, Jun 5 2013 8:45 PM
Hello,
I was wondering whether or not I could use a mcp 5500 in combination with a bc9000, the product page sais: "Unlike the MCP 5000, it used what were essentially Beolink 1000 codes but required an additional code to be sent by the Beomaster to allow two way control. Only the Beomaster 5500,6500 and 7000 provided these signals so it was of limited value with other systems." So are the possibilities limited(and how limited) or is it useless?
Thank you!
Wouter
tournedos
Finland
Posts 7,357
It will be very limited and extremely annoying. I suggest you save your sanity and forget about the idea.
--mika
Wouter
Netherlands
Posts 302
Wouter replied on Wed, Jun 5 2013 9:09 PM
tournedos:
well, thank you! I will!
Wouter
Page 1 of 1 (3 items) | RSS
