hello guys ive just bought a beomaster 4500 amp mint condition, and just got a 4500 cd player to match so exciting !!,when i ought the cd player the old chap demonstrated it for me at his home , so i bought it he popped in the transit screws and of i went home set it all up last night and the cd player will not play at all just goes to standby mode ,ive cleaned the lazer no luck, any suggestions please thanyou
Welcome to forum. Iconic kit the 4500 range.
No suggestions to your problem but I am sure someone here can help.
Hello Roland, If you are looking for confirmation of what I told you on the phone you should try searching the forum.
I suggest that you type C2103 in the search box.
Regards Graham
I presume you removed the transit screws?
hi graham ,thanks for your reply yesterday im, just a little disapointed with the cd player ive got a chap to replace the c2103 on the servo board but need to purchase one first any ideas im sure you will know regards roland
thankyou
I'll send you one Roland. No problem.
In the post at lunchtime. You should receive it in the morning post.
Good Luck
