the Beo Center came into My repair shop , with the right channel low in volume no distortion ,just most noticable in reference to the left channel. this is on phono ,and radio ,and tape.on all inputs... ,the left Channel is fine , I'm working with the original service manual ,
I have checked all voltages on both power output channels and they appear to be equal , I'm now working my way back toward the TDA1074 I.C.
any thoughts or suggestions ?
thanks to all ...Gus
Electrolytic capacitors in the signal path.Very often to see the larger ones on the tape board go bad.
