beogram 3300
bidstonhall
Thailand 5560 miles from Struer
Posts 363
bidstonhall Posted: Mon, Jun 10 2013 9:59 AM
hi guys, was given a beogram 3300 today for free, guy bought a lot of gear in the auction, was not interested in the beogram, it appears to work o.k. although no cartridge as usual, the lid is present but has been removed and no sign of the four screws
the buttons on the lid are damaged or missing also, the sensor for 45 and 33 lights up, i put a record on the platter and the arm moved across o.k.
is there any other test i should make before i start the long process of cleaning the brown film that is all over it, if it comes up o.k. i will look for a cartridge, any tips appreciated, cheers
kammeri
Posts 49
kammeri replied on Tue, Jun 11 2013 9:06 PM
Hi!
Congratulations on your excellent purchase! If the platter is rotating freely, its suspension is working, the arm is moving linear and up/down and the unit responds to commands via BC3300, BC9000 etc. you should be fine.
When purchasing the cartridge I would recommend buying a newly produced or refurbished one (i.e. Axel). My BeoGram came with an original cartridge which looked mint but sounded somewhat crappy for the suspension of the stylus had dried out.
Best Regards!
bidstonhall
Posts 363
hi, thanks for your reply, the arm is not moving up and down but i presumed it was because there is no cartridge in situ, hope that's right
Page 1 of 1 (3 items) | RSS
