Gentlemen,
I have recently acquired a BV6 which does not start up at all. All it does is light the green led which eventually (after a couple of seconds) begins to blink green/amber. This is about all it does. Has anyone got any idea about the cause? Furthermore, are there methods to troubleshoot the unit further in its present state?
Best Regards!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Thank you for your quick reply! That should not be the case for the unit doesn't even start up to reach the state of asking for the PIN code.
At least I am under the impression that there is no master lock up mode which prevents the screen from lighting up to ask for the PIN or master code. Please correct me if I am wrong.
I have the exact same problem! i would be verry interested to hear if someone have any sugestion what could cause this problem!
//Mikael
