Beogram 1200 speed regulator snapped!
This post has 5 Replies | 0 Followers
MrRoast
Posts 340
MrRoast Posted: Sat, Jun 15 2013 7:50 PM
Hello all,
Could do with a bit of help or advice please as I've snapped my shaft! Big Smile
It's an old Beogram 1200 in Palisander that has been in the loft since I acquired it and have finally got round to making it presentable. Unfortunately at some point its speed regulator spindle has been bent effectively stopping it from turning freely.
Trust my luck that I go and snap it trying to get it back on the straight and narrow! Angry
Can anyone suggest a solution?  Does anyone have a spare!? I'm kicking myself here!
Søren Mexico
Mexico City
Posts 6,411
If nobody comes up with a spare. Go to a machine shop, and ask them to make one. I can make one here but that will cost in shipping.
MrRoast
Posts 340
MrRoast replied on Sun, Jun 16 2013 4:55 PM
@ Søren - thanks! I think I've got a solution though. It looks like the threaded part is the same as an M3 machine screw (I hope) - I'm going to get a 30mm brass one and try cobbling something together!
MrRoast
Posts 340
MrRoast replied on Tue, Jul 2 2013 8:43 PM
Update - success! I've used a brass M3 machine screw and used the Dremel to cut to correct length and then shape the head to match the original spindle. Hopefully this will help is anyone has the bad fortune to snap theirs!
Søren Mexico
Mexico City
Posts 6,411
MrRoast:
Good job, thinking out of the box is the solution to many problems with vintage, enjoy the Black Magic music
MrRoast
Posts 340
MrRoast replied on Wed, Jul 3 2013 1:32 PM
@ Søren Mexico - cheers! Just got to figure out why I'm only getting the left channel audio now!?!
Page 1 of 1 (6 items) | RSS
