Beovision 4-50 with Beosystem 2: Can I add a 2nd DVI card into the Plasma Panel
This post has 10 Replies | 0 Followers
stampfki
Posts 138
stampfki Posted: Mon, Jun 17 2013 8:37 AM
I would like to connect another HD source to my Beovision. In the panel is a 2nd slot where I could add a DVI module beside the one which is already assembled. In the Beosystem 2 service menu I can allocate this 2nd slot to source like DTV or PC e.g. Does anybody know of this works?
Cheers
MartinW
Posts 389
MartinW replied on Tue, Jun 18 2013 12:14 AM
It certainly does! Have done that several times.
stampfki
Posts 138
stampfki replied on Tue, Jun 18 2013 7:19 AM
Great, so I am going to buy the DVI kit from B&O.
Does is support HDCP?
stampfki
Posts 138
stampfki replied on Tue, Jun 18 2013 6:08 PM
Does the DVI kit from B&O also support HDCP to get any rights protected contents as from Apple TV e.g.?
stampfki
Posts 138
DoubleU
Posts 562
DoubleU replied on Tue, Jun 18 2013 6:28 PM
Martin W,
2nd DVI-kit in a Beosystem 2? Are you sure?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Jun 18 2013 7:18 PM
Yoiu need a system 2 with software higher than 13.2. So it should be a mk2 or mk3.
With these system you can/need software 15.2 or higher. These software can assign a DVI to slot 2 or slot 3.
I've had 1 DVI and a component board installed in my BV5 several years ago.
DVI only supports 576i/p and 1080i, while component also supports 720p. Depends which D-model you have inside the BV4 panel.
Beobuddy
Posts 3,972
Beobuddy replied on Tue, Jun 18 2013 7:23 PM
A general DVI board from will do the job. It hasn't to be a B&O one.
Your computer (if you attach one) will see the DVI as B&O panel. But the system 2 needs only the RS232 data to recognize the panel by the system.
Normally you need to flash the panel with a flashtool (D7 officially supported by B&O) as you need to copy all the display settings for each used slot in the panel.. Otherwise the colours etc are not the same  as when you use the VGA (standard used by the system) input.
stampfki
Posts 138
stampfki replied on Wed, Jun 19 2013 1:51 PM
Beobuddy:
I thought using the B&O kit exactly avoids the necessity of the panel flashing.
I found an instruction how to enter the panel service menu where you can change some hex address values. Is that what you mean by flashing?
Beobuddy
Posts 3,972
Beobuddy replied on Wed, Jun 19 2013 7:55 PM
No, it is not.
If you buy the B&O DVI, like I did, then it comes with a note that  tells the dealer to flash the panel.
You only need the system software which makes it possible to choose the right slot.
stampfki
Posts 138
stampfki replied on Sun, Jun 29 2014 7:54 PM
Anybody tried this with a HDMI blade for the slot instead of the DVI?
Page 1 of 1 (11 items) | RSS
