BEOLIT 12 owners
This post has 1 Reply | 2 Followers
plumber77
Posts 76
plumber77 Posted: Tue, Jun 18 2013 7:22 PM
Just a general question for anyone who has a beolit 12.
I am thinking about taking the plunge. Was considering an outdoor speaker setup but the missus is quite taken with the Beolit 12 plus she says she can move it around the house whilst cleaning (and if it keeps her cleaning it's cheaper than a cleaner)
Are there any issues with airport express distance from the unit?
Secondly my BS9000 has aiport express direct into the aux input so I can stream from my mac to it.
I presume I could stream via itunes to both the BS9000 and to beolit 12 at the same time?
I have had a listen in the shop it I do like it alot but I suppose it's different to when you get one home
regards mark
BeoMegaMan
Posts 601
I've had one since it came out and I think your making a great decision!! I use mine with a Cisco router, but have had many customers who use them with Airports and have had great success. Obviously each home is a bit different. We take ours to the pool and outside all the time and people always remark on the quality and unique look.
You can indeed stream both to your 9000 and Beolit 12 at the same time with Airplay!!
Ah, you know... A little B&O here, a little there
Page 1 of 1 (2 items) | RSS
