Just a spare moment, and couldn't resist.
3 sets of penta's. Even without having neighbours, what would the passing/walking audience think?
(who let their dogs out )
All are MK3's, but with minor differences on the exterior and major differences on the inside...
Lovely!
//Bo.A long list...
and also in the picture, the world's most pointless BeoLab 11 .....
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou:Will you be using them at same time?
I would be!
THAT IS AMAZING!
I do tend to listen on the loud side and clearly you do too!
Enjoy!
Beo4 'til I die!
I did only connect four penta's....Didn't have more cables (the right fully wired ones, otherwise they don't switch on)
And tonight 1 set goes back to it's owner, so more experimenting isn't possible, sadly
9 LEE: and also in the picture, the world's most pointless BeoLab 11 .....
Just for decoration at the moment. The wife likes the shape of the tulip. So it stays there. Temporarily not used.....
Great looking set up even if it is only for a few days.
Beobuddy:Just for decoration at the moment.
Glad you found a use for it ;-)
1 van deze sets is van mij. Ben blij dat ze gereviseerd zijn en voorzien zijn van nieuwe onderdelen. Kunnen er weer tegenaan.
Bedankt, Ton Leenders
Thanks Ton!
I hope you can relax, enjoy and explore your music collection again.
