Beolab 8000 foam strip / seal - where to buy?
This post has 7 Replies | 2 Followers
mcm
London, UK
Posts 34
mcm Posted: Sat, Jun 22 2013 6:22 AM
I am replacing the frets on my Beolab 8000s and noticed that part of the black adhesive foam strip / seal that runs along the side edges is missing. Does anyone know where you can buy replacement foam strip?
Tried to google it but could only find foam / neoprene strips that are too large in width.
Many thanks in advance
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Fri, Dec 27 2019 4:55 PM
I would recommend this thin but double sided tape.
It works like a seal, like the B&O seal strip.
https://bit.ly/2P6L6rc
PaulGiles
Posts 218
PaulGiles replied on Fri, Dec 27 2019 5:37 PM
The B&O dealers can still source these, we had some recently.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Fri, Dec 27 2019 6:16 PM
Thanks Paul for adding this comment.
Is there any internet source for online ordering of this seal strip?
Do you know any source for ordering the white replacement foam for inside the BeoLab 8000 casing?
(Replacing the original dark grey foam that dissolves)
Beozip
Posts 368
Beozip replied on Fri, Dec 27 2019 6:23 PM
maybe this ?
https://www.ebay.de/itm/Bang-Olufsen-Dampfungsmaterial-Dammung-BeoLab-8000-B-O-BeoPlay-Beo/153684452032?hash=item23c84ea2c0:g:DSwAAOSwunNdpIEJ
PaulGiles
Posts 218
PaulGiles replied on Fri, Dec 27 2019 9:19 PM
I will find out entire spares still available and report back.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Dec 28 2019 10:02 AM
Thnx for sharing Beozip!
That's what I meant.
Though, I think the price is quite high. So I am looking for an alternative:
  • A better priced offer.
  • Or the same material for self-cutting.
If you know suggestions, please let me know.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Dec 28 2019 10:03 AM
Thnx Paul, looking forward to your info!
Page 1 of 1 (8 items) | RSS
