My RX2 runs slow. 24 rpm instead of 33. I installed a new belt and it ran at 28 rpm. How can I get it up to 33 rpm? If it needs a new motor, where can I buy one?
Welcome to Beoworld. Is this RX2 new to you, and you've never known it to run at the proper speed? Or have you owned it since new and one day it didn't work right? Where did you get the belt?
There are ways to repair motors (lubrication) mentioned in other threads on this and the archived forum. Try searching. Most decks have speed adjustment potentiometers ("pots"), some easier than others to access. Also try searching.
Also, post in the Beogram thread. You'll get more and better help there.
Lastly, I have two working RX2's and a box of parts. I may have a spare motor if it comes to that.
