Hello,
I have a trouble With my masterlink cables.
I have a beovision 7 link With masterlink to beosound 9000 and link With à wireless 1 to a beovision 6
i have got sound from beosound to beovision 6 and beovision 7 .
Sound from beovision 7 to beosound work fine but i have nô sound from beovision 7 to beovision 6 ( DVD or tv) With wireless.
help please.
excuse me for english but i live in belgium
Check that your BeoVision6 link TV is tuned to the correct version of PAL on the link frequency. The wrong setting will give you video but no audio.
Opman
When you select an audio source from the bv6, does the indicator light on the wireless turn:
A) green and stay green? - probably not a wireless issue
B) Green then red? - try unplugging wireless, wait, plug back in, wait for light to turn green then red, try selecting audio source
C) Flash orange? .- wireless cannot see other wireless, try to pair them again
D) other - ?? Don't know
Stan
Do any of those sources have analog audio connected or just HDMI? I believe early versions of BV7 did not down convert the HDMI audio signal to analog out through Masterlink. That may be your issue?? Pure Speculation though.
Ah, you know... A little B&O here, a little there
Thanks for your answers.
I have got sound from beosound 9000 to beovision 6 with the wireless 1 so i think the wireless and beovision 6 work fine.
I have sound from beovision 7 to beound 9000 with master link cable so i think beovision 7 is good too.
I have no sound from beovision 7 ( idem with avant) to beovision 6 with wireless.
If your Beovision 6 is a 26inch version, it has it's own modulator built in and in order to use it as a slave in a link room it must be set to option 6.
Ron
Thank you vert much.
V.option 6 was the good solution for me.
