RL6000 Stand help...
Playdrv4me
USA
Posts 477
Playdrv4me Posted: Sun, Jun 23 2013 9:51 AM
Hey guys,
I got some stands for my RL6000s (thanks for identifying I could use the 60.2 stands with the 6000s) but I can't figure out exactly how they work. The stands have a flat piece at the top with some flanges that is secured by two allen screws. At first, I thought that maybe this assembly somehow screwed into the speaker but it looks like the speaker just "rests" on it?
Regardless, when I place the speaker on everything (vertical orientation with B&O logo at the bottom right, I've heard this is optimal) it's angled down to the ground instead of an upper angle. I can not figure out how to turn these parts around in whatever way is necessary, or worse if I'm missing pieces, that would make the speaker angle UP instead of down at the ground.
I don't know what model number this stand is so I can't even find the manual to read it.
Thanks in advance.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jun 23 2013 10:03 AM
There should be a threaded screw hole towards the bottom of the attachment piece - this holds a flat headed screw that you can adjust in and out to adjust the angle of the speaker.  I can't find a picture, and my RL60s are with my son in UK.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jun 23 2013 10:05 AM
Picture 6a at the options guide here - you need the 'adjustment screw' - it screws into hole in the middle of the bottom of the square metal piece that forms part of the speaker. http://www.beoworld.org/manuals_view.asp?pid=659
Playdrv4me
USA
Posts 477
Playdrv4me replied on Sun, Jun 23 2013 10:12 AM
Thanks for the quick reply.
I'm not a premium member so I can't see the attached file, but I can get an idea of what you're talking about. I think what you're saying is that the "stopper" that on the Beovox S80.2 stands is on the stand itself, something similar is screwed into the speaker on the RL stands.
I obviously don't have this, so now the question is how to improvise, and where it goes.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jun 23 2013 10:23 AM
Found a piccy - you simply insert a flat headed screw into whichever of the 4 threaded holes is at the bottom according to which way your speaker is orientated.
Playdrv4me
USA
Posts 477
Playdrv4me replied on Sun, Jun 23 2013 10:30 AM
Guy, you're a lifesaver. Thank you very very much.
As it turns out, just browsing around ebay it was kind of amusing to see how many of even the "complete sets" being sold, are looking at the down angle just like mine, so the screw must frequently go the way of the do-do bird on these!
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jun 23 2013 10:33 AM
No problem - glad I could help.  And I had exactly the same problem when I first tried to set up my RL60s!
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Jun 23 2013 5:47 PM
Brengen & Ophalen
Page 1 of 1 (8 items) | RSS
