i have a beovision10/40 with connected AppleTV. Beo 4 > AppleTV control with puc work perfect.
Now i try to control the AppleTV with the BeolInk App via mlgw. (TV,Radio,DTV etc works)
Up, Down,GO etc dont work. only the "Exit" button working/receiving on the Apple TV.
Sources Setup for Apple TV on MLGW is: Source:V.MEM / Dst:TV / UI Type:Generic
Any idea ?
Ah, you know... A little B&O here, a little there
i change the UI to Generic + Arrows + Colours, Unfortunately no difference, only the EXIT key is detected.
Did you save the new configuration, which will activate it ?
And maybe you should change Dst from TV to VTR. Not sure if this helps but maybe worth a try...
Stefan
thanks, but I already tried.
I have found a solution for me:-) , I change the PUC settings from "Apple Remote" to "Apple Universol dock".
Now it works both -Beolink App + Beo 4
anyway thanks for your tips :-)
yes is true. software Build 153.
